With the latest release of GS7 the growing window problem has returned. It is a little different this time.
If my window is about 1/4 size of the full screen, (27’’ iMac) and it’s located near the bottom left it will grow taller each time I quit and relaunch. Like it’s not storing it’s last window size/location.
Thanks. We’ll look into this. I believe the window size and position are correctly saved, but the operating system has problems restores these value for windows with certain types of toolbars. We are trying to workaround these issues, but it’s pretty complicated.
I do have a program called ‘Moom’ that sets up windows automatically to pre-saved sizes and positions. The growing occurs even when GS7 window is not set by Moom. Even so, maybe this program is causing additional complications.
@ilja I have just tried with the last release and the problem seems to be disappeared… well, I tried quickly and I will be back here if it returns while working for lots of time. Anyway… I hope you solved it.
