50 Listings not reset to zero
I have used up my 50 listings per month in October, but the counter has not been reset to 0 at the beginning of November. Could you check this. Thanks.
Problem solved, Thank you.
I just hit my limit, too, and I’m not a big enough seller (yet) for Pro. When does the limit reset? Is it by calendar month? Or does it reset every 30 or 31 days? If the latter, how can I tell when it will reset? Thanks.
I think it is reset at the beginning of each calendar month.
GS resets on the 1st of every month.
