just to let you aware of some further issue I met…
- select a huge number of listings (inside many categories and subcategories) > change 30-days to GTC > switch to “advanced” in tab > uncheck “relisting” > switch back to “option” > duration is “blank” (like different durations are selected) although I changed it to GTC > try to open the window: what’s that??
select a huge number of listings (inside many categories and subcategories) > change 30-days to GTC > switch to “advanced” in tab > uncheck “relisting” > switch back to “option” > if switching from “option” to “advanced” take some time, doing the contrary (from “advanced” to “option”) takes much more and let GS freezing with spinning ball.
select a huge number of listings that are ALREADY all GTC (inside many categories and subcategories) AND make sure there is at least one listing inside that is on a different ebay site (like .com between all other .it) > check that “duration” is set to GTC (it is since all listings are already GTC ) > switch to “advanced” > switch back to “option” > now the “duration” is blank, but inside all listings are GTC. If you unselect and reselect again, GTC is correctly displayed.
