I can read and write SKU in my javascript but I cannot enable SKU checkbox. I.e. when I set SKU the I see that this number appears in this listing’s Options:SKU field but it’s grayed out. I have tried to set useSku prop to True (not documented) just like other properties have it but it didn’t do anything. See attached screenshot. Is there a way to enable/disable SKU from javascript or is it something that was forgotten to be exposed via javascript? Thanks!
Thank you for the reply! Then this is a bug in GS because GS has this checkbox and only allows entering SKU after you click on it, otherwise it’s grayed out. But in javascript I can set SKU without “checking” this checkbox. It’s a question to the devs really.
