Just purchased the subscription and when went back to GarageBuy… all favorites were gone.
Tried to reinstall both on Mac and iPhone but nothing
is it possible that you either changed or logged out of your iCloud/Apple ID account? This is the way the syncing works between the devices.
Also: can you tell me from which version to which version did you update? The subscription itself should not be the reason for any changes to your GarageBuy data.
Best Regards,
