When I select any number over 10 listings and select “stop listings” only 10 of them stay in the queue and the rest are disappeared. This behavior happens while using a smart group. A work around is to tag those targeted for stopping but it is easy to forget and then the search begins for those random ended listings. In my screen shot example I selected 25 to “stop” and only 10 stay in the selected group after GS performs the stop. The only way to keep track of the total ended group is to tag them before performing the stop and I sometimes forget.
