Garage sale lists dozens of profiles that I never created for shipping and returns, and then requires me to select one. I would prefer just to use my default template instead of selecting a profile. Is there any way to disable using the profiles in GS?
Yes, just select your own settings in shipping, return and payment fields (all together, you cannot use profile only for one of the three fields). Then go to ebay and delete all the profiles GS automatically created, if they are not in use (if they are, revise listing within GS and then delete the profile in eBay).
Sorry about the profiles, eBay creates them for you automatically, because they decided "that’s good for you"™.
