Hello! I went from a older iMac to a newer one… I made a template, then I did AppleScript to run batches of the template… I am able to create templates, but they are generic, so I need to figure out how to link my template to the AppleScript so it batches(repeats) my template listing…
I’m struggling to figure this out… I would be willing to pay for the help… if someone who is good at garagesale will message me, include ur contact info and I can text you… I think it’s a simple fix, (code line, redirect, etc)
Thank you so much!
Hello!
I was able to create an AppleScript that can creat batch templates… I run the script and it works fine… only problem is it’s a generic template… how do I link the template I created/saved to have that template be the one the AppleScript uses…
Thanks
Hello! I could sure use a little help, and am willing to compensate for your help.
- How do I save a template I created?
- How to I access this template when using AppleScript so all the listings it opens are from my “saved template”
Thank you!
I’m not sure I fully understand what you want to achieve. I suppose by template you mean an eBay listing?
Have you checked the 'Create New Listing" example from Help menu:
tell application "GarageSale"
set theListing to make ebay listing
tell theListing
set title to "New Listing Created from AppleScript"
set description to the (current date) as styled text
set convert description to HTML to yes
set primary category id to 14909
set duration to five days
set private listing to no
set condition description to yes
set use starting bid to yes
set starting bid price to 0.99
set use buy it now to yes
set buy it now price to 20.0
set use quantity to yes
set quantity to 3
set use sku to yes
set sku to "my personal stock unit"
end tell
end tell
