I keep seeing the warnings in eBay US that I “must” change listings with First Class Package shipping to be USPS Ground Advantage. This is a lot of listings, for me, so I spent a few minutes to write a script to help me find them.
- select the listings first
- the script will check any Shipping Option to see if it’s “USPS First Class Package”; it doesn’t have to be the first you’ve assigned
- it will add a blue tag if the listing does match, and will remove the color tag (entirely!) from any listing that does not match
- you can use a Smart Group to collect all listings that do have a blue tag, for further editing
- obviously you can edit this to find the string searched for, if you need to re-use for other purposes
Note that the entire script includes the handlers "on makeMyChange" and "on clearMyChange", not just the "tell application" part.
on makeMyChange(thisListing)
tell application "GarageSale"
set the tag of thisListing to 6
end tell
end makeMyChange
on clearMyChange(thisListing)
set the tag of thisListing to 0
end tell
end clearMyChange
set shippy to (the shipping option of theListing)
tell shippy
set serviceNames to {}
repeat with thisItem in its ebay shipping service
set end of serviceNames to (the service name of thisItem)
end repeat
end tell
if (serviceNames contains "USPS First Class Package") then
my makeMyChange(theListing)
else
my clearMyChange(theListing)
end if
end repeat
end tell
