Attributes warning delay
GS 9.7.5. macOS 14.3.1. This is a long, long time bug but I figure I may as well report it. I type or paste a title for an item in the attributes field [eg: a book title or DVD title]. The warning that there is no title still appears. I end up always ignoring the red dots because they are often not accurate. The listing will post. But clearly there is a lag. If I click back into the field, then the red dot goes away. But if I remove the title, the red dot does not appear until I open the attributes field up again. See short video for an example.
Thank you for making the video.
I can’t promise anything but we will check if there is a way to improve the error detection/update interval of the Preflight window.
FWIW, the red warning icon stays on the listing for hours/days, even after the title has been filled in. Some fields trigger this, others don’t. I guess the title does since it is required.
