Hi, I’m going to try the auto cancel / auto restart process
reading the manual, it says “Specify whether you wish to relist the item with or without any changes you made to the listing in GarageSale since you listed the original on eBay.”
but my only choices in the dropdown are
Relist with Changes
Relist with Image and Description changes
I have mine set to relist with changes and if you haven’t made any changes GS relists without any changes. i have done 1,000’s of relists this way and no issues have come up. I actually didn’t know there was a choice. I am not sure what the difference is between those 2 choices. They both mean the same to me
