I have all my listings set to Best Offer enabled. However, after auto cancel and auto restart runs the listings are showing a Best Offer on eBay even though it shows on GS in the options setting.
If i revise the listing even without any changes, then the best offer shows on eBay
As it is, the easiest way to fix this problem is to bulk edit on eBay, but I should not have to keep after this.
Could you export and send us the listing you are using, so we can easily try to re-produce the issue? You can either post here directly or send it to garagesale@iwascoding.com via E-mail.
