Hallo,
nachfolgend die Ausgabe aus der Konsole, ich habe fünf Bestandsartikel angeklickt, vier bei denen nichts angezeigt wird und einer bei dem alles ganz normal angezeigt wird.
standard>15:40:28.193074+0100|GarageSale|[C24.1.1 Hostname#215f6bf2:443 ready resolver (satisfied (Path is satisfied), interface: en0[802.11], ipv4, dns, uses wifi)] event: flow:child_finish_connect @0.544s|
standard>15:40:28.193171+0100|GarageSale|[C24.1 Hostname#215f6bf2:443 ready transform (satisfied (Path is satisfied), interface: en0[802.11], ipv4, dns, uses wifi)] event: flow:child_finish_connect @0.545s|
standard>15:40:28.193353+0100|GarageSale|[C24.1.1.1 IPv4#269423e3:443 ready socket-flow (satisfied (Path is satisfied), viable, interface: en0[802.11], ipv4, dns, uses wifi)] event: flow:changed_viability @0.545s|
standard>15:40:28.193464+0100|GarageSale|[C24.1.1 Hostname#215f6bf2:443 ready resolver (satisfied (Path is satisfied), interface: en0[802.11], ipv4, dns, uses wifi)] event: flow:changed_viability @0.545s|
standard>15:40:28.193548+0100|GarageSale|[C24.1 Hostname#215f6bf2:443 ready transform (satisfied (Path is satisfied), interface: en0[802.11], ipv4, dns, uses wifi)] event: flow:changed_viability @0.545s|
standard>15:40:28.193624+0100|GarageSale|nw_flow_connected [C24 IPv4#269423e3:443 in_progress parent-flow (satisfied (Path is satisfied), interface: en0[802.11], ipv4, dns, uses wifi)] Output protocol connected (endpoint_flow)|
standard>15:40:28.193767+0100|GarageSale|[C24 IPv4#269423e3:443 ready parent-flow (satisfied (Path is satisfied), interface: en0[802.11], ipv4, dns, uses wifi)] event: flow:finish_connect @0.545s|
standard>15:40:28.194152+0100|GarageSale|nw_connection_report_state_with_handler_on_nw_queue [C24] reporting state ready|
standard>15:40:28.194180+0100|GarageSale|[C24 IPv4#269423e3:443 ready parent-flow (satisfied (Path is satisfied), interface: en0[802.11], ipv4, dns, uses wifi)] event: flow:changed_viability @0.546s|
standard>15:40:28.194252+0100|GarageSale|Connection 24: connected successfully|
standard>15:40:28.194317+0100|GarageSale|Connection 24: TLS handshake complete|
standard>15:40:28.194606+0100|GarageSale|Connection 24: ready C(N) E(N)|
standard>15:40:28.194902+0100|GarageSale|Task .<1> now using Connection 24|
standard>15:40:28.195005+0100|GarageSale|Connection 24: received viability advisory(Y)|
standard>15:40:28.195347+0100|GarageSale|Task .<1> sent request, body N 0|
standard>15:40:28.431258+0100|GarageSale|Task .<1> received response, status 200 content K|
standard>15:40:28.431618+0100|GarageSale|Task .<1> response ended|
standard>15:40:28.431720+0100|GarageSale|Task .<1> done using Connection 14|
standard>15:40:28.431883+0100|GarageSale|[C14] event: client:connection_idle @11.255s|
standard>15:40:28.431993+0100|GarageSale|Task .<1> summary for task success {transaction_duration_ms=11262, response_status=200, connection=14, protocol=http/1.1, domain_lookup_duration_ms=56, connect_duration_ms=4124, secure_connection_duration_ms=4118, private_relay=false, request_start_ms=6197, request_duration_ms=2, response_start_ms=11261, response_duration_ms=0, request_bytes=1245, response_bytes=279, cache_hit=false}|
standard>15:40:28.432056+0100|GarageSale|[C14] event: client:connection_idle @11.256s|
standard>15:40:28.432668+0100|GarageSale|Task .<1> finished successfully|
standard>15:40:28.692814+0100|runningboardd|Invalidating assertion 383-5610-10697 (target:[app<application.com.iwascoding.garagesale9.12736139.12736360(501)>:5610]) from originator [app<application.com.iwascoding.garagesale9.12736139.12736360(501)>:5610]|
standard>15:40:29.099322+0100|runningboardd|Invalidating assertion 383-352-10691 (target:[app<application.com.iwascoding.garagesale9.12736139.12736360(501)>:5610]) from originator [osservice<com.apple.coreservices.launchservicesd>:352]|
standard>15:40:29.103714+0100|runningboardd|Invalidating assertion 383-378-10693 (target:[app<application.com.iwascoding.garagesale9.12736139.12736360(501)>:5610]) from originator [osservice<com.apple.WindowServer(88)>:378]|
In der Regel sind alle Bestandsartikel in Verwendung, Gemeinsamkeiten keine Ahnung, die Artikel sind alle nach dem gleichen Prinzip aufgebaut, Preis, Bilder, keine Artikelbeschreibung.
Anbei vier “defekte” Artikel
Viele Grüße
Torsten
Fehlerhafter Artikel 2.gsinventory.zip (1.8 MB)
