With eBay messing big time with their promotions next week, I need a tool to better manage them [eg: only promote after X number of days that an item has listed]. eBay’s API does allow for this. Flipwise [web app] allows this - they have a feature where when you re-list after X days, you can also add the item to be promoted at whatever % you decide. This can be automated so that every 30 days an item is ended and re-listed and then the first time it is re-listed, a 2% promo can be applied to the item.
Is there any roadmap for having GS manage promotions either manually or automatically? Thanks!
