Hi, I’m using GS on my 2011 iMac running High Sierra (10.13.6) and using GS Scout on my iPhone SE (iOS 17.3.1).
6 out of 10 times Scout imports into GS just fine.
The other times Scout appears to freeze my internet connection which I have to reset to continue. Also, Scout crashes from time to time after taking pictures.
How exactly do you experience that “freezed” internet connection? Are you saying that you can’t access the internet (e.g. browse in Safari) when it happens?
Also, is there any chance you can upgrade your macOS system? High Sierra 10.13 is pretty old.
