the title explains the bug: if you manually start (NOT restart) a group of expired listings from a smart folder by clicking on the “start” button, original listings are not moved to the trash. If you do the same but selecting directly those listings (so not from a smart folder), original listings are correctly moved to the trash.
I hope it could be fixed soon.
Thank you
Federico
