Is it possible for the GS8 to be with the old design, white, not dark. I love it dark, it’s just not convenient for my coworker. Thanks!
So far you can’t define this within GarageSale directly but there’s a tool available called “NightOwl”:
“NightOwl allows you to easily manage which of your Apps should stay light, while your system runs in Dark Mode.”
However, I didn’t test it and I don’t know if it’s good or bad.
Thank you, will check that!
