I didn’t know if I was going to upgrade at first so I started with a blank database. Now I want to import my templates from GS 6 – is this possible?
Thanks!
Chris
Thanks!
Chris
Yes, you have to delete the folder Library/Containers/com.iwascoding.garagesale7 in your account’s home directory.
If you don’t see the Library folder, you have to make it visible from the View Options panel for your home folder.
Doing so will remove all the listings you create in GarageSale 7, so you have to export the listings to file first, before the deleting the Container directory.
Awesome support (as usual) - thanks for making one of the best apps I use (not just best for eBay, best overall - that’s huge praise!)
Thanks!
