How much disk space does your GarageSale.leveldb directory take up? You can get to that folder by choosing “Show Library Folder” from GarageSale’s help menu.
@ilja see my previous comment a couple comments back on that file size you requested. If I can just transfer that file, how do I merge it onto another machine with an existing build?
Sorry, but I can’t find where you list the size of the ImageLibrary folder. I can only see that your GarageSale.leveldb directory, which holds all your data except images is 206 MB.
You could just transfer to entire Library Folder from one Mac to another Mac, but you cannot merge two existing libraries or keep them in sync afterwards. That’s a feature with are working on at the moment.
I can’t answer this question but if you have a backup you could simply try it out on your own risk:
Open GaragSale
Choose “Help” Menu > “Open Library Folder”
Quit GarageSale
Rename the folder “ImageLibrary” from the window opened in step 2 to something like “ImageLibrary-Original”
Start GarageSale
If it starts up fine and is still able to open your existing listing you could remove the “ImageLibrary-Original” folder.
Again, you do this on your own risk.
Make sure that you have a backup.
