I have over 9,000 items in my trash bin. Trying to delete them gets an unending spinning wheel. Any help?
Are you using the method below?
The spinning wheel will EVENTUALLY go away. Walk away when you perform the delete action.
The spinning wheel is the bane of my life, too. Spoils a good experience.
What version of GarageSale are you running?
Could you please run the “Sample Process” command from the Activity Viewer under /Application/Utilities once you get the beachball when emptying the trash, so we can see where GarageSale is spending it’s time? Thanks.
