Have been using Garagesale forever, so not a newbie stupid error thing…
Have latest version. Using same old templates I always use. Can type into title but not into the text field. Can’t select text or manipulate, add, delete in any way.
HELP!
HELP!
are you using GarageSale 6.9.8 or GarageSale 7?
You’re referring to the item description field in GarageSale’s Preview mode, correct?
If you create a new listing from scratch (for test purposes), can you type in Preview mode there?
