I have been using Applescript modify existing listings and create new ones with most of the specifics set to what I need them to be. One issue I have been running into is that I can’t figure out how to change the condition from Applescript.
I have been using something like this: tellapplication “GarageSale”
set thelisting tothefirstitemof ( get selected ebay listings)
setthe condition ofthelistingto “Pre-Owned”
endtell
I have also tried to use typical names and id’s from the Ebay API reference.
I was having some issues changing some of the other settings such as the listing design and layout. The workaround I used was to set the defaults for new listings to what I use and create the listings from scratch with the rest of the information. I’m not sure if I just don’t have the syntax right or what. There isn’t a default condition though so the only other way I can think of changing it is going in afterwards and changing them to what I need but I would prefer to have the change happen through Applescript automatically.
Is there a way to change these settings from Applescript?
