Changing default item location after move
The online manual says:
“If you haven’t been using an older version of GarageSale, the welcome window lets you specify the eBay site you want your listings to appear on. You can also enter a default location for your items. These values will be used whenever you create a new listing in GarageSale and will show as the item location on eBay. You can change these settings from GarageSale’s preferences window at any time.”
However, I can’t see where in GarageSale’s preferences I can change the default location for my items… pls help!
In the GarageSale preferences > eBay > New Listing
just click on the Location option below the settings for the eBay Site.
Please see the first screenshot here:
https://manual.iwascoding.com/gs7/en/GarageSale_Preferences-eBay.html
To change the location in an existing listing just use the Location options in the “Advanced” Inspector sidebar in Listing mode.
