Changing to a new listing template in GS7 - Help!
I am using GS 7.0.7 (795). I have a new listing template which I have successfully uploaded to GS but I cannot bulk change by thousands of listings so that they are updated with the new template. I can only do it one by one!!! In GS 6 I could select all my listings and change the template in one go - is this possible in GS &, is there a workaround? Any help would be massibely appreciated!!! Thanks David
You probably forgot to select all the listings in overview mode!
Please see the animation here how to bulk edit:
https://manual.iwascoding.com/gs7/en/Listings_Section-Bulk_Editing.html
