Is there a way to filter/search/compare what is active/ended/sold to make sure I haven’t accidentally deleted ended items before relisting them?
I am not sure if I understood what you’re trying to achieve.
Can you maybe use the smart groups for that? E.g. create a smart group that lists all ended listings?
I’m wanting a way to compare what items have ended and what items are currently active.
My reasoning (which may help explain what I’m wanting to accomplish): I’ve been relisting ended items through the eBay site, and I’m concerned I may have accidentally deleted some ended items before relisting them.
Maybe there isn’t a way in GarageSale… I’m not sure if there is an easy way to compare the two or not in or out of GarageSale.
