When I try to select a subcategory under “Collectibles” I get nothing. I’ve updated categories more times than I can count, I’ve killed GS at least as many times, I’ve rebooted a dozen times, I still get nothing, nada for Collectibles. Wouldn’t be such a big deal if 60% of my business wasn’t Coillectibles. WTF?
Are you using the latest version of GarageSale, version 8.1?
It might be required to renew the eBay token completely:
Update the category data manually once again.
If this won’t help, please give this a try:
- Quit GarageSale if running.
- Open the macOS “Keychain Access” application and enter “GarageSale eBay Account” in the search field. (If you don’t find anything try it with “ebay token”.)
- Right-click on the eBay account token in the Keychain and select “Delete”.
- If done, restart your Mac, start GarageSale and add/refresh your eBay access tokens in the GarageSale preferences > Accounts.
