I don’t have any listings currently active so here is a screenshot of an old one to show you the configuration of drop zones I’d like to achieve, if it’s possible.
I’m not sure if I get request correctly, but I believe it’s about having the description split into several blocks by inserting images at certain places, right?
Here is one way to do it, that wouldn’t required a custom design:
Switch to editor mode.
Select the “No Images” layout from the design popover button in the toolbar
Within your item description, insert blocks like below at the appropriate places:
(This one would insert the first image. You need to change the two “0” into “1” etc for other images… Here is a screenshot of how to use this construct several times:
