I have an error
Connection error
Unknown authentication error from ebay’s OpenAPI
Tried to refresh the api token but button seems to be stuck
Any ideas
Richard
I have an error
Connection error
Any ideas
Richard
what version of GS are you running?
Hi
Version 9.2.1 (1503)
Was running correctly a few months ago
Updated it yesterday
When refreshing tokens, I can now log partly into ebay, but second screen where it asks "Verify your contact info:
We’ll text you at 7xxxxxxx78* with a security code.
The get “Text” button does not work
(Will work with ebay in firefox, tested separately)
Google id login button option will not press either
Thanks
Richard
Thanks
Richard
It might help to temporarily disable 2FA on the eBay website or to change it from “Text” to “eBay App”.
Yes that’s the solution
But authenticate 2FA and it automatically sends a text to allow entry, which is authenticated when just entered
Well done
Thanks
Richard
