I can choose to copy components from one listing and insert them into an other listing.
There I can choose what components to insert.
But why I can not copy and insert the listings images?
Greetings,
Christoph
Greetings,
Christoph
Images can be copied directly via the Copy and Paste commands in Edit mode. Here is a short video showing how it works:
Thank you for your answer.
I know that your can do copy and paste. That’s how I do it right now.
But it is always two actions to take components from one to the other. First the settings and than copy and paste the images.
But I thought that images are also components of a listing and should be pastable in the paste components dialog.
Greetings,
Christoph
