I have an issue where the toolbar disappeared and the Hide Tool Bar option in the menu is grayed out. Also one of my prepared listings just shows a blank screen. When I quit GS and restart it it does not always open so I have to force quit and try again with intermittent results. I tried Auto-repair corrupt database but got the following message. “The operation couldn’t be completed. IO error: lock /Users/ Andrew/Library/Containers/ com. iwascoding.garagesale9/ Data/Library/Application Support/GarageSale/ GarageSale.leveldb/LOCK: already held by process”
I would restart the Mac and then give the database repair option another try.
If this won’t help, I fear you need to replace the database with the one from your backup.
Or try a re-index as well
