Crash on Import
I’m trying to import a CSV, as discussed in another thread, but now when I run the import on 500 items, the application crashes. I’ve attached the crash report to this note. Any suggestions for how to proceed would be welcomed!
Garage Sale Crash Report.txt (82.6 KB)
Can you provide us with your GarageSale Crash ID that you find in the “About GarageSale” panel?
Also, if you send me your CSV file I will try to check if there is an issue with that file/data.
