Creating proforma invoices from GS
I just discovered that GS no longer works with grandtotal. This was the only integration included in GS that could let me create proforma invoices directly from GS (which was extremely useful). Now this integration is broken, it actually doesn’t work. So now I am looking for any other solution to print proforma from the order. I thought to use a custom template to print from the order section, but I think it’s almost impossible to keep a continuous numeration in it (or am I wrong?). Is there anything else that I am missing? Or a fix for grandtotal or any other application like that is possible? From next year (two days) I am planning to find a solution for invoicing from GS.
Thanks for any advice.
Federico
