I have been trying to create some custom templates for garage sale. I read the manual, googled it and read through this forum but I just couldn’t get it working.
I started by duplicating an existing template (GarageSale.app > Show Package Contents > Contents > Resources > DesignTemplates) moving it to (~/Library/ApplicationSupport/GarageSale/DesignTemplates) and then editing it by hand/dreamweaver. No joy.
I then discovered that there is the DesignTemplateUtility.app … I downloaded that, duplicated a template, changed a few bits and then saved and then chose “Show in GS”. No joy. My new template just didn’t show up.
Now, I have copied the template that was created by DesignTemplateUtility.app and moved it inside of the GarageSale.app (GarageSale.app > Show Package Contents > Contents > Resources > DesignTemplates) manually. Restarted GarageSale and there it is. In the list with all of the other templates.
How come the DesignUtility.app saves it in a place that doesn’t actually read into GarageSale. How come all of the literature (that I have seen) says to save it in the ApplicationSupport folder … that doesn’t seem to work for me at all. Does using the mac App Store to purchase GarageSale make a difference to the location that custom templates are read from?
Anyway, it seems to the be working, in a way, although I have to make changes and then restart GS every time to see how it looks. Any answers/thoughts/solutions welcome!
