I accidentally deleted a template ( in design utility) used in my listings. The listings are now clean. can I fix the error by creating a new template and renaming it as the old one?
will the template be automatically associated or do I have to make a mass modification?
You right click and choose “copy design components” from the template you want and right click on the listing you want to add the design template and choose “paste design components”. You can choose as many as you want and do it in bulk.
Yes, as far as I can tell that should work. Just note that it’s important that the “new” template must have the same name and identifier as the previous one! Both can be set in the “General” tab in DesignUtility.
