Using GarageSale Version 7.0.14b5 (834), macOS Version 10.12.6 (16G1314)
If an Account is marked as “disabled” (Enabled is unchecked) in the Preferences window, is should not be “used”, nor attempt to “update” from eBay. I have 3 accounts, only one is marked “Enable this account”.
Should not “check” nor update “disabled” accounts…
- Console Output still happens for all 3 accounts. Should not do operations for “disabled” accounts!
Mar 4 10:01:12 Neal-Trautmans-iMac-Computer GarageSale[25650]: skipping GetOrders operation for account lambocountach, because other update operations are using the account Mar 4 10:01:12 Neal-Trautmans-iMac-Computer GarageSale[25650]: skipping GetOrders operation for account dmtinfla13, because other update operations are using the account Mar 4 10:01:12 Neal-Trautmans-iMac-Computer GarageSale[25650]: skipping GetOrders operation for account zmthath13, because other update operations are using the account Mar 4 10:02:58 Neal-Trautmans-iMac-Computer GarageSale[25650]: skipping Get Seller List operation, because account lambocountach is already in use Mar 4 10:02:58 Neal-Trautmans-iMac-Computer GarageSale[25650]: skipping Get Seller List operation, because account dmtinfla13 is already in use Mar 4 10:02:58 Neal-Trautmans-iMac-Computer GarageSale[25650]: skipping Get Seller List operation, because account zmthath13 is already in use Mar 4 10:02:58 Neal-Trautmans-iMac-Computer GarageSale[25650]: skipping Get My eBay Selling operation for account lambocountach, because other update operations are using the account Mar 4 10:02:58 Neal-Trautmans-iMac-Computer GarageSale[25650]: skipping Get My eBay Selling operation for account dmtinfla13, because other update operations are using the account Mar 4 10:02:58 Neal-Trautmans-iMac-Computer GarageSale[25650]: skipping Get My eBay Selling operation for account zmthath13, because other update operations are using the account
- Accounts window shows all 3 accounts. Should only show 1 enabled account. Or show other 2 disabled accounts as grayed out and not-selectable?
- These Three (3) popup menus show all 3 accounts. They should only show 1 enabled account (or none if only 1?).
A. “Start…” popup menu in Toolbar
B. Listing Menu in MenuBar “Start Listing…” popup menu
C. Left Listing Pane, Contextual Right-click popup menu, “Start Listing…”
