It seems that I duplicated some listings is a way that I am not really sure where to find the copies. The only way to check this is when I go listing by listing. I have 900 listings, all different clothing, so I really can’t do it manually (copy-pasting the title to check how many of the following are in the database). Is there any automated way, like the smart folders, so check for duplicated listings. If I upload the listings the way they are now, there will be multiple overlaps ( I only have 1 item per listing). Thank you very much!
Here is one thing that you could try:
- Create a new group
- Put all your listing in that group
- Right-Click on the group icon and choose “Sort by Name”
Now all similarly named listings should be grouped together. It should be easy to spot duplicates and remove the version you don’t need anymore.
Thank you, this worked!
