After a good year or so, the duplicate entry test seems to be done purely on the item title. Previously, it has included the image which then allows for the same title to be used.
Thank you for reporting this. Unfortunately, for me your post is a bit vague but I am guessing that you are referring to the “Duplicate Listing” error message from eBay?
First, some background: As far as I can tell GarageSale doesn’t check for duplicates itself. eBay does that when a listing is uploaded, under its Duplicate Listing Policy. So when a listing gets rejected as a duplicate, the decision comes from eBay. eBay doesn’t publish exactly which fields it compares.
Your observation might have to do with eBay’s new image upload API but that’s just a guess.
One thing that you might want to give a try: put the difference between the items into the listing itself, e.g. a distinguishing detail in the title or subtitle, or a different item specific. eBay weighs those much more heavily than photos.
Do you already had a chance to test it with the beta 5 of GarageSale 10.2? The final release of GarageSale 10.2 will be available very soon.
Yes and no is the answer.
I am receiving far more GS reported duplicate listing issues than previously - because the title is the same.
And, Some duplicates are actually making it through to eBay. When I checked Ebay status/duplicate listings there were 12.
I am running 10.2b3 (1842)
I will update in the morning.
I am suddenly getting more when scheduling restarts in 24 hours. 10 out of 30 relists. I ended 30 today and scheduled for tomorrow. They have been listing ok in the past. It looks like there is a lag time in the duplicates servers. They I am guessing they clear by the scheduled relist.
Indeed it seems to be a change on eBay’s side. I often have the several copies of the same used items and list them individually, with the corresponding serial number in the item description and individual images for each item. This has worked flawlessly for years, but today it’s no longer possible to relist such an item, because eBay claims it’s a duplicate of another item (even though the serial numbers and the images are different).
Interestingly, listing that item directly through the website worked…
