Hi there,
Just noticed when i create a template, give it an ebay category and specifics, when i duplicate the template all that information is removed? Is there a way to duplicate all that info when the template is duplicated?? ??
Thanks
Bob
Hi there,
Thanks
Bob
Hi - don’t know what version you are using, in GarageSale 6 its
PREFERENCES>ADVANCED
Miscellaneous
Remove Category After Duplication
uncheck that
That will at least preserve the category, should keep the attributes too.
Pete
Thanks so much, never saw that, had it unchecked on one machine but still checked on another.
Thanks
Bob
