Ebay token rejected? Garagesale 9.94
Getting a {“error_id”:“unauthorized_client”,“error_description”:“The OAuth client was not found.”,“http_status_code”:401} error when trying to authenticate token that expired for some reason. Can this be fixed?
I just replied to your message you sent to our support!
You are most likely using an older version of macOS, like macOS 10.14 or macOS 10.15. The current eBay authorization process is incompatible with older versions of macOS. If you want to keep using GarageSale in future we highly recommend to upgrade to a newer version of macOS (macOS 11 or better newer).
