I’ve just bought a copy of GarageSale and I want to delete the drop zone(s) in the template description because I am putting larger, higher-quality images there. How can I accomplish this? I’d really appreciate any help. Thanks.
Hi attima,
are you trying insert your own image URLs / img tags in the item description?
If so you could simply select the “No Images” layout.
You can insert your own HTML in Editor mode.
Thanks for your prompt response, Kristian. My starting point was the “No Design” layout. I can’t find a “No Images” layout. Do I need to download it from somewhere or where should I be looking? Best wishes, Philip
Hi Philip,
from the “Template > Layout” menu simply select the “No Images” option.
(or from the context menu in Preview mode)
Perfect. That solved my problem, thank you Kristian. Best wishes, Philip
