Error while uploading (56): Failure when receiving data from the peer
Mid-2007 24" iMac, OS X 10.11.6, GS 7.0.8, using my own FTP server hosted at bluehost.com. I have three listings waiting in the wings which cannot be posted because of this error.
I’m able to access (connect/upload/download/disconnect) the FTP server manually, through OS X terminal and through Cyberduck. When configured in GS the test image uploads and displays correctly. When I go to start my auctions the verification stage passes with no errors and I click START LISTINGS. The upload begins, then in a few seconds it errors out with “Error while uploading (56): Failure when receiving data from the peer”.
After this happens, if I login via terminal or Cyberduck I can see that two of the images have been uploaded. My listings have 3, 4, and 6 images in them respectively (13 images in total). The two successfully uploaded images are from two different auctions; one is from the 3-image item and the other is from the 6-image item. I can successfully download and view them so I know they’re completed uploads. There are also 11 more files in my ebay FTP directory, all of them created by GS and all of them containing 0 bytes.
I can’t answer your question but before you continue troubleshooting you should clarify if your server provides the secure HTTPS protocol. I mentioned this because https image resources are recommended by eBay.
What would ebay’s preference on HTTPS have to do with an image upload error with GS?
Nothing and I never said it does. I wrote “before you continue troubleshooting…” to save you for maybe unneeded troubleshooting work in case your server doesn’t support https.
this error comes from the underlying library libCURL that handles the (FTPS) request to your server. It means that the library can not read data from the server.
There is not much GarageSale can do about it as it is hard to tell which component between your Mac and the server fails to deliver the data. Can you increase the timeout on the server for such connections? That may help, but only if the connection timed out on the server.
Maybe it makes sense for you to switch to eBay’s (EPS) or our image server. Both of them are free (at least for non-GTC lisitings) and support the new HTTPS policy from eBay.
Ah, got it. My mistake, sorry.
libCURL is OS level, correct? If that were the case, wouldn’t any software that uses the same library (or even just using the terminal FTP commands) experience the same error when uploading?
After a fair amount of experimentation I think I figured out the issue, or at least the cause.
If I start an auction with ONE image, it works fine 100% of the time. If I start an auction with two or more images, I sometimes get this error. When the error does appear, the first image is always uploaded but the second image doesn’t if it’s “too large”. I haven’t figured out the exact numbers but when the second image is tiny, like 50K, it seems to work all of the time, but any larger than that seems to generate the error. When there are three or more images it always fails; again, the first image is always uploaded but any/all images after that fails, regardless of size.
I’ve seen this set of conditions before (like a decade ago) and the problem was always the same: too many simultaneous connections on an FTP server that doesn’t support simultaneous connectins. The problem seems to be that GarageSale is opening multiple simultaneous FTP connections to upload the images. If there are five images then GarageSale opens five simultaneous FTP connections, but if the server doesn’t support it then it fails. One image is fine; there’s only one connection. Two images works IF the second image is tiny; the connection (connect/upload/disconnect) happens so quickly that it’s faster than the FTP server’s “reaction time” to the second connection, but if the image is too large then the server kills the connection. Three or more images is right out; the FTP server kills the others immediately.
It’s easy to point the finger at the server and ignore the problem, but fundamentally the solution is simple: Put an option in GarageSale that forces single FTP connections. If there are five images, instead of having five FTP connections have a single connection and run all five uploads through that single connection. Yes, it’ll be slower, but it will also work and that’s more important, IMO. I believe FileZilla has such an option and I definitely remember seeing it in programs such as Dreamweaver, so it’s not like it’s an impossible or even particularly difficult thing to do.
I would very much prefer to maintain complete control, ownership, and permissions over my images, so using a third-party “solution” isn’t really viable.
