In macOS it is possible to expand and collapse all folders using Command Left/Right Arrow.
Is there a similar command on GS to expand and collapse all groups?
Hi David,
no, but if you hold down the alt key and expand a group, all groups inside this specific group get expanded, too.
So technically you could put all your groups into one single group and expand them all at once this way, I guess.
Wonderful Kristian
That gets me around my search problem.
You just need to fix up the Smart Group bugs now for me.
Cheers, David.
