Export Listings as .CSV?
Hi GS Team,
I wonder if there is a possibility to have .CSV data exported from GarageSale 8 listings? Importing is currently possible for:
  • title
  • sku
  • price
  • quantity
  • cost
  • barcode
  • description
I wonder if the same information can be exported? I am experimenting with some automation processes and wanted to see if created listings can export any data to .CSV? Specifically Title & Condition Details would be extremely helpful.
Thanks for your help,
-Anthony
GarageSale 8 has a powerful CSV import function but not a CSV export function, sorry.
That’s no longer true. With GarageSale 8 you can import various CSV formats:
Thanks for the updates for CSV import formats. I will experiment with automation Before importing to see if that works.
Otherwise, could iwascoding consider adding a feature to export simple CSV data fields?
There is a weird workaround for doing this via reports, but the only field that I need is something like Condition Details in addition to the item title.
That feature would be a godsend. I already asked in the past for an export feature. It has been years I am wondering about working with other sites like abebooks, but any solution I found implied leaving GS and still today I can’t work properly on any other site due to this lack…
@anthony_d if I can ask, how can you do these automation processes? It sounds interesting for me…
