Hi there,
I recently needed to find an order I had shipped earlier in the week, and had the Order ID number handy [called Seller Order ID in GS]. I was surprised, however, that pasting it into the Search field did not find the order. I made sure to remove spaces/tabs, and even tried to type it manually in the search field: 04-12348-65213, but GS does not allow one to search that field. I have All fields checked as can be seen in this screenshot.
Can this feature be added to a future release? Thanks.
