Okay, I’m new here and new to Garagesale, I’ve jumped right into the beta program
I imported my eBay auctions and it imported the current auctions and those awaiting dispatch plus all those completed for the last month. How do I file away the old completed sales, I would like to archive then not just delete them.
You can export listings (no matter what state they are in) into a separate file using choosing “File” > “Export Listings”. This will create a file on disk that holds all the listing’s information, which can you can keep and later re-import.
After the export, you might need to delete the exported listings by dragging it to the trash (and emptying it).
