My GS quit bring in final value fees. It looks like it just started.
I looked back through my history and final value fees stopped on 6/22 and 6/21 was the last entry. Hope this helps figure what happened.
That is when mine stopped also.
Does it help to refresh eBay tokens and select “Update all Orders” from the Order menu afterwards?
No help at all. It stopped on the last order on the 26 June.
That brought in everything EXCEPT 2 sales from the last 4 hours
Mine is still not working.
Some fees are showing up on report but not on orders. Mistake they are old ones. None are showing up. I revoked the access and reinstalled it still doesn’t work. I don’t know if anyone else uses reports to see if you are making money or I am the only one having this problem.
Just to let everyone know I restarted computer and all the fees came in. I don’t know why that made a difference but it worked.
Your computer lost part of its brains, Called the Microsoft solution in the Darkside
