Interesting - I would think the Dec 14th one could be re-listed. I guess it is shorter than 90 days then. ![]()
I tried again and then it went up. It was ended Jan 7
Aaah, I thought you meant the listing was ended Dec 14th. [which I would still think would qualify for re-listing, since it is within 90 days].
It started dec 14, I misread the dates. The Oct 20 was ending date and ebay said it wasn’t my listing to relist
Yeah, the Oct 20th is past 90 days, so eBay “forgets” about the listing after 90 days after it’s been closed. That’s the conclusion I’ve come to, but I can’t find my data to show that is 100% certain how it works [I did a test a year or two ago and I am 99% certain I found that 90 days was the max I could re-list a closed item].
I remember all the way back to the days when you could search the last 90 days of your own (or any other user’s) purchases.
You still can.
I’ve used that feature quite a bit [I also use the feature that allows you see what another seller has sold in the last 90 days].
