Great news! Is there any specific order that you are updating GarageBuy? So I know what bugs/UI experience I can focus on and report?
Thanks iwascoding Team,
Kim
currently we just updated the underlaying SDK so it properly runs on current macOS versions. We fixed some retina related bugs and added a required header above the details for eBay.
Seems a little buggy. I replaced an older version - which I didn’t use - with beta.
Spinning wheel symbol against several searches which never seems to finish.
Check for updates tells me there is an update available, but trying to install update crashes the app. (report below)
Imported ebay searches.
GaragePay imports searches but sets them to search in All Categories whereas on ebay they were set to search in books only for the vast majority.
Thank you Kristian, my main point was that the loaded listings disappear. I can’t favourite an item if i see one because I need to click OK to get rid of the warning.
