thanks for your feedback. To be honest, I never thought of the Dark Mode when raising the macOS version that is supported. So now I have to decide to either disable or fix the Dark Mode
I also just found out that copy and paste does not work in this beta. More specifically the copy function - when I mark text in the description of an item.
I also do have the 3.4 version with 10.15.5 macOS.
I tried different listings it’s all the same.
When I copy text and press cmd-c then I get the error sound.
Kim
I have one more issue to report:
On 3.4 version with 10.15.5 macOS.
After I view all unread items and open Garagebuy e.g. next day. All items I read last time appear again. So I need to mark them as read again. This happened already several times.
Hi Kristian, first of all thanks for the great support.
It was not Pop-clip. I just deleted and reinstalled GB and it’s working now. I’m not sure what it caused.
