FANTASTIC!!!
Reordering in Preferences window works GREAT!!!
But… when first launching I get the “Loading database…” dialog and the spinning beachball (and Activity Monitor shows 100%) for a couple minutes. Then main window showed up. ???Database update/conversion???
Initial loading of transactions takes ALOT longer than v1.8!!
Second and subsequent launches and it was faster… Main window showed up and spinning beachball for a few seconds… Main window shows 1927 transactions… Another Main account has 34775 transactions…
Reordering while it is “searching for transactions” seems to result in a stuck spinning beachball. Here is a spindump:
I should have waited to re-order til it was done searching and updating, since I’m only gonna re-order one time…
So… I force-quit, re-launch, WAIT TIL DONE UPDATING (which seems to take longer than v1.8), no Internet access during spinning beachball, just “processing”…
“In this version, you should be able to reorder the accounts in the preferences and they should be ordered the same in the main window.”
Yes, this does work!
Also, I have my transactions sorted by date, and they are definitely no longer sorted by date… And clicking the sort-by-date column header doesn’t sort by date. See photo:
After “searching” completes, if I click to sort by date then it does sort correctly…
When I change accounts, the sorting is not maintained/remembered and is incorrect.
And changing accounts takes MANY seconds with a spinning beachball.
Thanx Paul!!
GaragePay 1.8.1b1 Spindump.txt.zip (193.5 KB)
GaragePay 1.8.1b1 Spindump 2.txt.zip (207.0 KB)
GaragePay 1.8.1b1 Spindump 3.txt.zip (175.8 KB)
Screen Shot 2018-12-01 at 5.23.36 PM.png.zip (1.1 MB)
